I am using the ctrl+enter feature to make my equations fit on one page. every time I need to factor it spreads it back out across 5 pages and I have to do it again. is there a feature to keep the original format of the equation?
You can't control the output of the symbolic processor, if that's what you mean.
Never mind I found it.
Hi. This is a workaround, for some cases (for example, without radicals).
Copy the symbolic answer
Right click in the paper and choose "Past Special"
Sometimes the option "Unformated text" is avaible
This is the result:
Best regards.
Alvaro.
