Hi all,
Anybody has already same idea.
Launching LTSpice from MathCAD Prime 8.0 calculation results ; or generally produce a text format results from MathCAD prime.
Best regards, Habib.
Hi ! Great ! I’ll see about WRITETEXT() in prime 8.0. Thanks !
Best regards,
Sure, its possible to write text files (so also LTspice input files) using Prime.
Look up the function WRITETEXT().
Prime is not great at starting other applications from within, so launching LTspice....
Best regards,
From "Help Center" - "About Functions for Reading and Writing Files": https://support.ptc.com/help/mathcad/r8.0/en/index.html#page/PTC_Mathcad_Help/about_functions_for_reading_and_writing_files.html
See here for some additional input:
