Limit does not take into account the assume keyword...Or?
Cornel
In the end, the result should not be:
The calculation was made in Mathcad Prime 8.
(To:Cornel)
not?? Why not?
"assume" never was reliable and satisfying.
But in this case it seems that it got worse, as the old symbolic in P6 returns the simple result
Cornel
(To:Werner_E)
Mathcad Prime 8 cannot calculate such kind of limit...
And assume does not work in Mathcad Prime 8 (at least for this kind of problem)...
Any workaround for Mathcad Prime 8?
(To:Cornel)
None that I would be aware of apart from using the absolute value or the square for variables which are considered to be positive
Werner_E_6-1682581562614.png        Werner_E_0-1682581077569.png          Werner_E_1-1682581085482.png
Erroneously Prime does not distinguish between y=0 and y!=0 here.
Only correct answer so far by MC11 with Maple, shown by Luc.
You may consider reporting this bug/inability to PTC support.
BTW, sometimes "assume" actually IS respected and works as expected 😉
LucMeekes
(To:Cornel)
Guess you're right:
