Link Variable from another worksheet to another
Tidus
Helou,
im newbie in Mathcad. I have question about this problem (in teoretical way): I wanna use one variable from worksheet 1 (where is calculated) to another worksheet 2 as imput to calculate the output.
Can i do this with hyperlinks?
I think MathConnex can do this?
Any idea?
thanks
Vlado
PhilipOakley
(To:Tidus)
Reference sheets are the answer
Insert > Reference
This effectively inserts (by reference) the whole sheet at that point so the variables and their values are available from then on.
Philip Oakley
Tidus
(To:Tidus)
hmm but when i change variable in worksheet 1 then in worksheets 2 dont update..(i have set automatic calculation).
hmm?
Vlado,
You're right. It doesn't update on the fly, but only if you reload worksheet2.
What does worksheet1 do? Is it used stand alone as well?
Either way, I suppose worksheet1 contains some functions, where variable1 is input.
If worksheet1 is useless without worksheet2, you could consider to move the definition of variable1 to worksheet2 BEFORE the reference to worksheet1.
Additionally be sure that Worksheet1 only contains functions. In Worksheet2, AFTER the reference to worksheet1 you can call any defined function (also when it's defined in Worksheet1) with a.g. Variable1 as parameter, and get the result.
If worksheet1 does have a use without/apart from worksheet2, you might consider using a (another) wrapper worksheet around Worksheet1 for that purpose.
Hope this helps,
