Listbox
ptc-4260912
Listbox
When the selections inside a listbox are text. Mathcad will assign the row number of the selected item in the list to the variable . is it possibel to have the variable = the text of the selected item in the list? Thanks !!!!!!!!
RichardJ
(To:ptc-4260912)
See the attached example.
6 REPLIES 6
just to clarify my question above:
if The listbox Code:= ASD
LRFD
where ASD are the selection in the listbox, when i select LRFD, then Code=2
is it possible to have Code="LRFD" rather than the row number?
becuase all my condiional "if" statments are based on the condition of whether "Code= "ASD" or "LRFD"?
Thanks!
i am attaching a mathcadsheet to clarify my questions above. Does the script for the listbox need to be changed to be able to accomplish it?
RichardJ
(To:ptc-4260912)
Great. Thanks alot Richard!
Great Thanks Richard!
if i would like to create a listbox for the variable "Beam" to have all the beam sizes in column "C" of the attached
excel spreadsheet down to row 275. i will have the excel sheet in C:\ Database. how would you do it? Thanks!!!
