After windows update, i can no longer use the CTRL+SHIFT+M shortcut to add a math region on the canvas or in a text region.
I use this shortcut heavily every day, anyone else have the same issue?
PHEW.
OK, I fixed it by doing a clean boot of my computer. Multiple restarts through windows did not fix the issue.
To get a clean boot, shut down windows through the start bar and then physically turn on the computer again.
What Windows OS are you using?
Windows 10, been using it without any issues for over 2 years
Version 10.0.19042 Build 19042
CTRL+SHIFT+T for text region works just the math region one is disabled, very annoying and severely limits how i use Mathcad
Mathcad Express 7.0.0.0, Win10 Version 10.0.19043 Build 19043 works fine. No reboot required,
Stuart
PHEW.
Thanks for this tip in the end!
