I am still using MC 14.0. I had to re-install it because the motherboard on my computer went bad. Now, when I go to the Trace tab in plot format it comes up blank and clicking on anything but cancel crashes the program. Other tabs are fine. I installed the M020 release but that did not help.
Any suggestions?
Thanks to all who offered suggestions. The (or, at leas, a) solution turned out to be incredibly simple. When my computer guy tried to install M020, he unpacked the files to a location that was different from the default. M020 then installed without difficulty and for reasons that he did not know (and I certainly do not) that solved all the problems.
What Windows OS are you using?
Windows 10 although I was also using that before I had to re-install MC14.
1. Try to repair it Mathcad 14: "Control Panel" --> "Programs and Features" --> right click on Mathcad14 icon and select "Repair". When ask for Mathcad14WixInstaller.msi browse for it: Mathcad14_EN folder -> Mathcad -> Mathcad 14.0 M020.msi.
2. The following Microsoft add-on requirements also apply:
VladimirN: Thanks for the suggestion, but I could not find the file Mathcad14WixInstaller.msi. I did find the Mathcad 14 M020 installer, but when I tried to repair using this file, I get the message "This action is only valid for products that are currently installed". When I try to re-install I get
I have been using the M020 installer that I downloaded quite a few years ago when I was having trouble re-installing MC 14 on a new computer. When I tried to download the installer again, I get the message "Failed - network error".
Luc: I tried dowloading MC 030 for installation, but the link in the release notes took me to "Nothing to see here. The page does not exist." Contacted PTC in the chat box on the page but an hour later, they have not responded.
Nothing seems to be working for me today.
John,
A little later I will look at the contents of the pack for the M14 M020 service release. Which download version do you have available from this link: https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=MCD ?
P.S. Here you can find M14 M020 service release: https://support.ptc.com/support/mathcad_downloads.htm
I have been using the the link in your P.S. It seems to download the file but then I get the message "failed - network error"
I tried the other link, but evidently, I am not authorized to use it. It seems I need a PTC account.
1. Can you show a screenshot of the package contents for M020 service release?
2. Windows Installer (.msi ).
https://docs.microsoft.com/en-us/dotnet/framework/install/dotnet-35-windows
https://dotnet.microsoft.com/download/dotnet-framework/net35-sp1
https://www.catalog.update.microsoft.com/Search.aspx?q=973688
Hi Vladimir,
Thanks for your help but I am still having some problems. I did manage to re-install MC14. Although I got a number of error messages, it seems to be working. When I try to install M020, I get the error message shown in the screenshot. Presumably this is related to errors I got in installing MC14 Another screenshot shows the contents of the M202 service release, as you requested. I think I have .NET Framework 3.5 - see third screenshot.
If you have some feedback let me know, but I will not have much time to spend on this for the holidays. Once they are over our computer tech guy will be back and he can help. I will get back to you either way. Till then, have a happy holiday!
John
Hi John,
Also go through the steps described in this post: https://community.ptc.com/t5/PTC-Mathcad/Installing-Mathcad-14-0-M020-with-Add-On-Collection-on-64-bit/m-p/298973/highlight/true#M116720
Glad you solved your problem!
Hi John,
It appears that there is a Mathcad14 M35:
https://www.ptc.com/en/support/refdoc/Mathcad/14.0/Mathcad_14_M035_RELNOTES_HTM_98347
But I see no fixes in M30 or 35 that (directly) relate to your problem.
I assume you have the prequisites installed:
HI Luc,
Thanks for the suggestions but I am having more problems rather fewer. I tried to install M35 update but the link in the release notes took me to a page that said "Nothing here for you to see - the page you are looking for does not exist." I tried the PTC chatbox on the page, but did not get any response - at least until now (~36 hours later). Another problem (see post on displaying an array) cropped up and Werner thought I have a faulty installation. So I uninstalled MC14 but now cannot re-install it at all. I keep getting the message "some files could not be copied - close all apps, reboot windows and try again." I did that several times, to no avail. I am using Windows 10 and successfully installed MC14 a few years ago when I had to get a new machine, so I think I have your "prerequisites" but how would I verify this? I searched on MXSML and there were many. MXSML SP2 is no longer available from Microsoft.
Any other suggestions?
In any case, have a happy holiday!
John,
Can it be that you're bitten by the bitness of Windows?
Was your previous Win10 a 32 or 64-bit edition? I suppose that with a new MotherBoard, and reinstall of Windows 10, you're now running the 64-bit edition.
Note that Mathcad 8 through15 are 32-bit applications, so chances are they require the 32-bit MSXML.
Just note that the regular version of Mathcad received support for Windows 10 only starting with the M050 service release.
Look like you are having a same problem as me!
What version of MathCad are you using? I am using MathCad 14. I had some problems a while ago when I had to install it on a new computer, but using the patch to version 020 solved them.
