MCD to xmcd converter Running VERY slowly
AG_1235069
7-Bedrock
I recently installed Mathcad Prime 9.  I had been using Prime 8 for a while. I have some files created with Mathcad 15 files (xmcd) that I need to convert to the new mcdx format but the conversion utility is taking a very long time to do the conversion.  It's been on "In Progress" for almost an hour on the first file.  I don't recall this being such a problem with earlier versions (Prime 7 and Prime 8).  Please help!
It looks like the solution was to NOT use the button in Mathcad Prime 9 but rather to run the converter program from the Start menu (Start->PTC Mathcad->PTC Mathcad Prime 9.0.0.0 XMCD MCD Converter.exe. The file conversions were done in a matter of seconds.
(To:AG_1235069)
One hour for converting a single file sure is quite unusual.
Can't compare to P7 or P8 as I skipped versions 7 and 8 (no big loss given the slow development speed of Prime). Also I have not converted a lot of files with P6 or P9 as I still use the faster and more powerful and convenient MC15.
But the files I converted so far took a few minutes at most to get converted.
Is it an especially long and complex MC15 file you tried to convert? If you can post it here I give it a try with P9.
(To:AG_1235069)
Strange! In my (limited) experience, there was no noticeable difference whether the conversion was initiated from within the program or the converter was called directly.
Maybe it might be worth considering trying a clean re-install of Prime.
