Make a range variable and a function of a range variable into a matrix.
gatlas
Team,
I have a range variable and a function of a range variable and I need to combine these into a single matrix.
The matrix would have two columns and 100 rows.
Please see the attached worksheet.
Dr. Atlas
LucMeekes
(To:gatlas)
A range is NOT an array, but you can use a range to create an array.
Once you have the (input) array, you can feed it to your function to get an (output) array; you may have to vectorise your function call.
You can plot the output array versus the input array, and you can augment the two arrays to form a matrix:
See attached worksheet!
LucMeekes
(To:gatlas)
