MathCAD installation problem
ptc-3932712
Hi there,
I think I'm having some problems with the license that was forwarded to me from PTC. When I show the path for the license, its says that the MathCAD is installed and is ready to use. But when I try to open up a MathCAD, I can't. It gives me an error. Attached, please find the problem that I'm facing.
I would appreciate your cooperation in this respect.
Ashehad
Please see the answer here: http://communities.ptc.com/message/183029#183029
mzeftel
(To:VladimirN)
Hi Ashehad,
If Vladimir's suggestion doesn't work, contact technical support at http://www.ptc.com/support/mathcad_supportCenter.htm.
Mona
I am using Math CAD 14 and have tried installing it on Windows 7 (64bit machine). Could this be a potential issue ??
Please advice ...
regards,
Ashehad
Hi Ashehad,
When running the installer, right-click and select 'Run as Administrator'.
If that doesn't help, search these pages for "Mathcad Win7 installation" and you'll see notes from others that had similar issues.
Mona
