MathCad 14 and PDE commands
ptc-2774551
I have the following diffusion problem form "Mathcad for Engineers" Adidharma et al. I have worked through several ODE examples successfully, however when working through the attached worksheet I receive the following errors, worksheet is attached. I have the following questions:
1)When setting up the function the derivative notation of d/dx or d/dt is allowed is this also allowed in the PDE solver?
2)In the book on Mathcad online it mentions that PDE Boundary Conditions are required to use "CRT F7" to setup a derivative, however when I do this I still have an error?
3)The online book also mentions that boundary conditions need to have literal subscripts using ".", I have tried entering the function "f" and then the literal subscipt "." followed by "x" however, this did not work?
Please advise what I am doing wrong. I have Mathcad version14. Thank you in advance.
Sincerely,
Walter
(To:ptc-2774551)
You have to omit the function arguments when you call pdesolve and also when you do the 3D-plot. Its the very same as in this thread of yours: http://communities.ptc.com/message/243735#243735
The attached file should help.
Hi Werner,
Thanks for the help but the fundemental reason that I was not able to figure out the issue is that the function with the PDEsolve needs to be re-typed in again from scratch if an error is corrected in the equations prior to the function with the PDE solve in it. Once I did this the problem was able to be solved and modfied as needed. This information is not documented in any book or other material I have come accross.
Sincerely,
Walter Stonas
Chemical Engineer
(To:ptc-2774551)
Iits not clear to me what exactly you mean by that!? It should never be necessary to retype anything from scratch just to correct a type or some other error. If autocalc is on, changes should update the whole sheet immedeatly. Sometimes it happens that an evaluation will not update (you see x= and nothing on the RHS) or that a a subexpression still is prited in red as if an error was thrown while its already corrected. In this case pressing CTRL-F9 to recaclulate the whole sheet or F9 to recalculate the current region should do the job.
