MathCad set of linear equation solution error
CG_10324365
Hi, guys I am trying to solve this equation and get the value of coefficients (alpha1,2,3) and it doesn't work. Is probably 'cause of derivation. You have and suggestions on how to solve this? I would like to use it in the future, so it should be parametric.
LucMeekes
(To:CG_10324365)
Which 'this equation'?
You need to attach the worksheet.
Is this what you are after:
Or, in one go:
LucMeekes
(To:CG_10324365)
Oh, you wanted the general case... Well, if M is:
and B is:
Then the three alpha's are:
