I have a problem where I go to install Mathcad 14 off the install CD and it fails to register about 20 - 30 different files. It also seems that it is missing files too. I tried running as administrator but to no luck. Anyone know a solution? Here is an example of the one of many files that are missing.
1. You need to preinstall some of Microsoft components (http://support.ptc.com/WCMS/files/98347/en/Mathcad_14_M035_RELNOTES.HTM#System_Requirements😞
2. Try to use this tip:
