Mathcad 14: Graph "Traces" causing "internal error..."
ptc-4284010
Hi
Please can someone help, having problems formatting graphs using the "traces" tab, the table is missing, then when I select another tab Mathcad crashes displaying message "internal error has ocurred...". I have tried repairing the installation and also completely re-installing to no avail.
hope someone may be able to help.
thanks
Shaun
12 REPLIES 12
Hello!
What version of Mathcad (and Windows OS) do you mean? This error occurs in any file?
Hi
It's Mathcad 14, installed on my rather ancient windows xp (sp1) pc, so perhaps that's the problem.
thanks
Shaun
What version of M14?
Mike
sorry Mike, Mathcad 14.0 M020 (14.0.2.5 [])
thanks
Shaun
Vladimir is correct, why not update to XP SP3?
Mike
Also, try updating to the latest Mathcad 14 service release M035: http://www.ptc.com/appserver/cs/software_update/swupdate.jsp
Oops, forgot about that. Well pointed out Vladimir.
Mike
Why be not updated to XP SP3?
Thanks, will upgrade to sp3 shortly, perhaps this is the problem.
attached a screen image of the problem. Thanks for all suggestions, will install mc update
Shaun
Also, here's a link to "Mathcad 14.0 - M035 Release Notes" (pay attention to the section "Software Requirements"): http://www.ptc.com/WCMS/files/98347/en/Mathcad_14_M035_RELNOTES.HTM
I was recently having this problem with Mathcad 14 and 15 (I tried uninstalling and reinstalling both versions). I am running window 7. I solved it with Mathcad 15. To solve the problem:
1. Go to uninstall programs
2. Find Mathcad and repair it
3. A box will ask for Mathcad15WixInstaller.msi browse for it (Mathcad15_EN folder -> mathcad -> Mathcad15WixInstaller.msi)
4. and BAM! problem solved
Hope this helps
VladimirN
24-Ruby II
(To:jstaker)
Thank you for sharing this tip.
