Mathcad 14 M030 release
ptc-3090709
Hi all -
After a few hours of searching, I am coming up empty and am hoping someone can help me. I need to know what new functionality was added to Mathcad 14 between service pack M020 and M030.
All I can find is that 'Results are not Automatically Updated when Using Inline Definition/Evaluation' was resolved with the M030 release.
Thanks for any help you can provide.
Emily
RichardJ
(To:ptc-3090709)
From the release notes:
Mathcad 14 M030 fixes and improves existing functionality and includes the following new features:
Windchill 9.1 M010 Workgroup Manager (WGM) support
New installer�You can now customize your Mathcad installation by selecting the language, components, and directories.
User interface translation into Russian
Bug fixes:
1436139 Addresses specific problems involving rapid consumption of memory upon repeated recalculation of a worksheet.
1502717 Fixes improper result returned when evaluating 2^31.
1507803 Addresses a specific memory leak issue relating to an uninitialized handle.
1507032 Addresses a compatibility problem resulting from an improvement in how numeric tolerance in integrals was inferred.
1547641 Fixes PDF file generation problem on Window XP x64 machines.
1437427 Fixes in-line evaluation to update display to match available value.
1587915 Addresses a WRITEPRN restriction by increasing the maximum allowable string length from 128 to 1024.
1403321 Addresses specific memory release issue involving large worksheet computations.
That's all.
Richard
Thank you so much for your quick reply. This is very helpful.
Thanks!
Emily
They have also changed a lot of the registry
settings for 'extras' such as paths for handbooks,
templates, etc. (e.g. such as the language sub-
directory)
This has caused me much grief and I still have a
call open.
Philip Oakley
Under Announcements comference
http://collab.mathsoft.com/read?132151,2
"Mathcad 14.0 releases M030 and M035 were designed specifically for enterprise customers and include integrations with PTC�s Windchill and ProductPoint ... "
So, it is assumed that normal users needs M020 release.
Also see:
http://collab.mathsoft.com/read?122748,2
http://collab.mathsoft.com/read?128915,2
Regards. Alvaro.
