Mathcad 14 Page Setup Problems
JulianHague
I have an unusual problem, when I saved the file the dotted line was in the correct place for A4. However when I opened it and did a Print Preview the dotted line had moved. I have attached snips of the Page Setup, the file as saved and the page after previewing it.
How can I make Mathcad accept that the page is actually A4 not Letter????????
Julian,
Can you attach your worksheet or a smaller part of it, if it's too large. It will be easier to investigate the issue if there's a worksheet to test.
Mona
Have attached the relevant file.
MikeArmstrong
(To:JulianHague)
There is defiantly something up with that worksheet.
I have just opened in M15 and got the same problem, so I copied all regions to a new worksheet and they all fit on a single A4 page.
Mike
Well crap.
If you insert a page break at the end of your calculations, it will print on one page.
If you display the tables as a matrix instead, it works as it should also.
So its a bug realted to dispalying as a table.
