Mathcad Community Challenge May 2024 - Polyhedrons and Platonic Solids (Part 1)
DaveMartin
This month’s challenge is inspired by Dungeons and Dragons and Stranger Things. D&D involves spinning dice, which are regular convex polyhedrons. The most common dice used are d4 (tetrahedron), d6 (cube), d8 (octahedron), d10 (decahedron), d12 (dodecahedron), and d20 (icosahedron), where ‘d’ is for die and the number indicates the number of sides. In this challenge, we will focus on the Platonic solids, which are the regular polyhedrons made up of regular polygons (the lengths of each side and interior angles are equal). In other words, skip the 10-sided die.
Most references define regular polyhedrons as a function of the edge length of one of the polygonal faces. In this challenge, we are defining the regular polyhedrons by the radius of the circle that circumscribes a polygonal face.
Your challenge is as follows:
  • Derive the surface area of the regular polyhedrons as a function of the radius of a circle that circumscribes a polygonal face.
  • (Optional) Derive the formula for the volume of one or more of the regular polyhedrons as a function of the radius of the circle that circumscribes a polygonal face.
  • Create a calculator where the user can select a regular polyhedron by its name or number of sides, and for a given radius of the circumscribed circle of the polygonal face, the surface area (optional: and volume) will be calculated.
  • You can use a Combo Box input control for selecting the polyhedron. The ambitious can use one of the advanced input controls available in Mathcad Prime 10 (just released April 10th).
  • After the user selects a polyhedron, the number of vertices, number of edges, and Euler characteristic for the polyhedron should be displayed on the worksheet. (Hint: you can’t calculate the number of vertices or edges, so you will have to store them in a Combo box, matrix, or table.)
  • (Optional) Using the Chart Component, graph the surface area (optional: and volume) as a function of the number of faces. (Hint: add a 2nd Y-axis if including volume.) Assume a radius of 100.
As always, documentation is key! Someone should be able to read the worksheet and understand what problem you are trying to solve. Have fun!
Find the Mathcad Community Challenge Guidelines here!
Dave Martin - dmartin@creowindchill.com - https://www.mcaeconsulting.com
20 REPLIES 20
Some additional links about polyhedrons and Platonic Solids that may be of interest:
https://www.cuemath.com/geometry/polyhedron/
https://www.varsitytutors.com/hotmath/hotmath_help/topics/platonic-solids
https://www.splashlearn.com/math-vocabulary/geometry/polyhedron
(The latter two can be share with your kids, as they are intended for a younger audience.)
ttokoro
20-Turquoise
(To:DaveMartin)
Prime 10 with plots. Tokoro.
ttokoro
20-Turquoise
(To:ttokoro)
Add r=1 plot.
ttokoro
20-Turquoise
(To:ttokoro)
Add resistances of 1 edge and most far points.
DJNewman
(To:ttokoro)
Ah, yay, more checkboxes!
I manage the Creo and PTC Mathcad YouTube channels for PTC, as well as all PTC Mathcad marketing in general.
DJNewman
(To:ttokoro)
Clicking the checkbox for painting in the plot is really fun.
Here's my limited attempt using Prime 8 Express.
Alan
ppal
(To:DaveMartin)
My first Prime 10 Document. No plots!
No specific units used for the Length.
Here's my function heavy attempt.
Thanks for your submission. What name should we use in the blog write-up?
Oops, I tried replying to this message and it appeared under another message. What name should I use for you in the blog post about the challenge?
You can use
Patrick H
ttokoro
20-Turquoise
(To:DaveMartin)
ttokoro is OK.
T.Tokoro.
I thought I might need to check some of the math using a 3D CAD model, so here is an icosahedron modeled in Creo 7 if anyone else wants to do the same.
And here is a tetrahedron for anyone who wants to play around with it.
The last day for the challenge is tomorrow. But here are some Creo 7 octahedron models.
May ends in a week, so if you want to tackle the Community Challenge and be featured as a challenger in our write-up (and get an exclusive Community badge for it), time is running out!
Thanks, everyone, for your Mathcad worksheets. Expect the blog write-up in a few days.
And I still need to figure out how to make a dodecahedron in Creo Parametric.
Okay, dodecahedron created in Creo 7.
This is coming a bit later in June than I would've liked, but finally, the blog is up and the badges are distributed:
https://www.mathcad.com/en/blogs/community-challenge-platonic-solids
My next task is to set up for the next challenge, which will be... out of the ordinary and special! And starting next week.
