I am trying to adjust Mathcad Prime Header and footer margins to suit the Working area of the Mathcad Prime-10, but I am not able to do, please help me about this, the files are attached here for easy understanding.
Thank you
I guess requested functionality is not implemented. To be sure, please ask PTC Support.
You can put picture into Header, as shown in following picture.
Hi, Thanks for the replay. Ok will do as per your suggestion.
You are talking about this
I, too, could not find an option to fix this.
I would call it a bug or sloppiness in software development that this was not thought of.
It is also very strange and inappropriate that the grid size in the header apparently cannot be changed.
The corresponding button only changes the grid in the main area.
You may consider reporting the issue to PTC support.
Good luck!
Thanks for the Reply, ok will report PTC.
