Mathcad Prime 2.0 - Current name and path
cairo-2
We just updated from Mathcad 15 to Prime 2.0 and we have to solve some compatibility problems.
First of all, we had, in the Mathcad 15 version, a worksheet with a component (button) ; this component used to get back the worksheet.name, it means the name of the current mathcad worksheet.
I'm trying to replace this component, in Prime 2.0, by a function.
I found that the path and the name of the current mathcad worksheet can be called in the heading.
Is there any way to get back this path in the sheet ?
I don't want to manually copy/past the path from the header to the sheet, I need to do it automatically.
If I can't do it automatically, I have to create a ini.txt file, containing the names of all the mathcad worksheets intended to be used one after one, and do some re-writing stuff in each mathcad sheet to the ini.txt ; it's not a clean way to do that, and it brings some constraints for the futur user.
Thank you for your answer or ideas,
Cecile
cairo-2
(To:cairo-2)
Just for info, we finally choose to create an extra-subfolder for each mathcad worksheet, name-based on each worksheet's name ; and we re-create the name with the CWD.
As I said before, it's not a clean way, but it works...
I'm still interested if you have any solution for this version of Mathcad.. or if I missed something huge ?
Thanks for reading,
Cecile
