I'm trying to use the solver to solve 4 unknowns with 4 equations. I keep getting the error "No solution was found". I can work the answer out easily enough by hand and all the similar examples I have found seem to work just fine. What am I doing wrong? Help!
Ah! Silly me. Solution found! The M_overturn value needs to be a positive value in the final constraints equation.
Thanks for one good idea! Can somebody solve this task more interesting ![]()
