The formula I have typed into Mathcad is quite long and goes beyond the print area of the page.
I was wondering if there is a way to force the formula to run over onto a second line? Or is there anything you recommend to do otherwise?
... In case it makes a difference I'm using Mathcad Prime 2.0.
Thanks!
The only way around it is to break the formula down in defined variables and summate them below.
Mike
MathCAD 15 used a control enter to provide continuing to the next line. Will this be added back in for Prime2?
No, hopefully in Prime 3.0
Mike
