Im having trouble transferring my calculations from my private Computer ( PTC Mathcad 10 version trial) , to my university Computer (Version 9)
Directly opening the new version Files, on old version is ofcourse not possible
Copy Pasting it in a external document and inserting it in the old version also does not work
My Question is,
Is there any way of transferring my calculations from new to old version ?
(It is not posible to make any aditional Instalations on Uni Computer)
Remove Prime 10 from your home pc. Install prime 9 onto it, in (unlicensed) Express mode. Then install prime 10 again on it. Now you have both prime 9 and 10 on the same pc which you can run in parallel, and you can copy regions over from a prime 10 sheet to a prime 9 sheet.
Hello @FF_11098405,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
