I recently purchased the mathcad prime program. I work on multiple different devices, all are owned and used by me. Is there a way to access my software license on multiple devices without paying more? I believe I have a node locked license and not a server hosted license. If I am able to access the license, how do I set it up? Thank you in advance.
Node locked means just that! The license is restricted to a single computer (node).
If all of your devices are on the same network, you can get a floating license, but that will cost more.
If you need portability (laptop computers off network) multiple node locked licenses are the most practical method.
"How to verify if a license is of a floating or a node-locked type for PTC products": https://www.ptc.com/en/support/article/CS250157
