Hello everyone,
Could someone help me figure out why the options in the outputs of m and n programs are repeating, while the program k works fine? Is there anything i should change in Bop() function?
Attached the Mathcad sheet.
Hi @NM_10165576
Thank you for your question.
Best regards,
The reason is Bop() function's Layer number. It makes the difference.
Yeah i got it. But what i did not understand is, why the options are repeating only when the layer is 2 or 3.
If you only want to derete the m and n programs repeating data,
I did this already. But i just want to know the reason for the repeating values. Thank you anyways.
The number of lines of the results depends on floor() function. If it is 3 then it makes 6*2 lines.
You can add 1 or -1 after it, then you can find the change.
