Hello all.
Is that possible integrate MathCAD with RSD?
Where can I find documentation about this?
What is RSD?
RSD = Routed Systems Designer
Ah, I see! It has to do with that "Other World" over in Creo-Land You might be better off asking over there, if you haven't already.
More about Creo Schematics (formerly Pro/ENGINEER Routed Systems Designer) can be found here:
http://www.ptc.com/product/creo/schematics/
http://www.ptc.com/WCMS/files/128133/en/6667_Creo_Schematics_DS_EN.pdf
Hello!
Danilo Calzavara wrote:
...integrate MathCAD with RSD...
Such integration doesn't exist. Among PTC products integration Mathcad 15/Mathcad Prime 1.0 with Creo/Elements Pro 5.0 and Creo Parametric 1.0 is carried out (also for the given integration there is a documentation and a training course from PTC University is present).
P.S. What kind of task you would like to solve with this integration (Mathcad and RSD)?
Hi Vladimir
I need to export some MathCAD variables into RSD.
Like, I have a form in MathCAD that must be completed by the User.
With this completed form, five design variables are generated, and these variables are parameters in RSD that influence the choice of the elements of the schematic.
Why format does RSD accept?
Mike
Mike,
The following screenshot shows available formats for the import data option into Creo Elements/Pro Routed Systems Designer 9.0:
