Merge 2 prime files or worksheets
jdesai-2
Can you merge or join 2 mathcad prime files together and save it as one file? I don't want to use the copy and paste, I have different headers, footers etc, and copy/paste creates a mess.
6 REPLIES 6
LucMeekes
(To:jdesai-2)
I guess it may be doable, by messing around with the individual .xml files. But I'd expect, if..... you succeed in doing that, you may get a real merge, that is: equations on top of each other because they are on the same position of the sheet...
I suggest you use copy and paste to copy just the equations over. That's safer.
jdesai-2
(To:LucMeekes)
Thanks LucMeekes, is there an insert option available, like insert these pages from this file at this location in this file. (something similar to MS Word)
DJF
(To:jdesai-2)
If you just want them to work together, you might consider the 'include' function.
Otherwise I think you are stuck with copy-paste.  Not sure why your headers or footers makes a difference.  But copy paste can create a mess since it doesn't always create room for what you are pasting. Option 1 - manually add sufficient space on where you're going to paste.  Option 2 - I've found that keeping everything inside collapsable areas works well.  You can copy and paste the areas without issues.  (Although using areas tends to bring on other issues - fix your GUI PTC!!!)
jdesai-2
(To:DJF)
where is this include function?
jdesai-2
(To:jdesai-2)
what does the big green exclamation mark mean?
DJF
(To:jdesai-2)
Input/Output tab at the top.  I guess it is a feature, not a function.
