Mid-Line Fault Calculations
ptc-5133430
Most faults occur at a point on a line some distance from the substation bus. The current seen by a line protection system during a mid-line fault is typically much less than that for a bus fault, and varies in magnitude depending on the position of the fault relative to the end-point buses.
0 REPLIES 0
