I just started having an issue where some of the variables in the math region are "missing" when I click outside the math region. They reappear when I click in the math region again. The equations and any solving performed gives correct answer, only the symbols (or numbers) are missing when you click outside the math region. I opened several other Mathcad files and see the issue there as well. It looks as though the missing variables occur when there is a fraction involved and it doesn't matter if it is character or numeric. I noticed this started after opening a Mathcad file I received from someone, but all of my previous Mathcad files show same issue.
I tried to re-install Mathcad 15.0 thinking I may have corrupted a file or something, but this didn't work.
I notice that the characters disappear if I change the zoom factor to anything but 100% and they stay missing regardless of whether I click in math region or not.
I also have Mathcad 14.0 so I installed that and it happens with that version as well.
Can you attach your Mathcad worksheet to the message?
Actually it seems to have fized itself after I rebooted the computer. I can't get it to happen again. If it comes back I will include the worksheet. Thanks, Robert
I have seen this come and go in M14 and M15, usually when I embed equations in a text region. Only for me, is is usually the other way around...they disappear in the text region until I click outside the text region. I associate this with editing the equation significantly just before it disappears...I suppose that the rendering engine doesn't handle the change well until I click outside the text region and it gets a chance to redraw the whole region.
~R~
