How do I change my email address. My current email will be void at the end of August and I find no way to change it on my profile or settings.
This forum does not use its own logins but (unfortunately) uses the logins to PTC support. The data is kind of synchronized, but important data like your mail address can only be changed at PTC support.
So when you login to this forum, go to Support | PTC
At the upper right corner you should see your real name, click it and chose "Manage My Web Account". You should be able to change your mail address there (Tab: "My Profile").
Thanks much!
Thank you VERY Much!
