Neg Seq Ended Fault locator.mcdx
ppal
18-Opal
File to locate faults on a Transmission Line. Based on Schweitzer Negative sequence method. File can be modified to accept phase currents and voltages and then calculating the Negative sequence values.
0 REPLIES 0
