I have been a long user of Mathcad, back when it was a DOS program. Currently I am using v15 but am planning on moving to Prime 5. On some of my project I have to load six or more spreadsheets. The multiple spreadsheets are loaded at the same time, via nested matrix. Each cell has a READEXCEL for each case. The individual matrix is accessed using the indexes. I have two questions:
1. Will Prime support a similar method of reading multiple spreadsheets?
2. What is the change in performance?
I had been holding off on making the change because I have to have 2-D plotting for data checking and presentation.
I think you'll be ok. I have an example where I load 8 csv files, each 70k rows long and it works very well. However, if you ever try to paste even a few hundred rows (appears as a table) Prime does not like that and bogs down quickly. Anyway it shouldn't take long to try - the converter isn't perfect but should get you close. Worse case (or best case as others will argue) you just stick with 15.
