New User with a Programming Question
CoreyKerns
I am a Virginia Tech Grad student and a Coast Guard officer doing some thesis work in Ship Design. I am using MthCad to program an Energy Calculator that will calculate fuel usage for different engine plant configurations. I have come a across a problem that I need help with.
Could someone explain to me how to program a MathCad file to use a discreet choice to decide which equations to use. I though the "if" command would work but it doesn't seem too.
In my program there are three discreet choices for how to calculate the fuel usage and these choice depend on plant configuration, i.e. mechanical, electric, and hybrid.
The equations for each plant type would use the same variables. So how you program MathCad to say if Mechanical follow these equations, if electrical follow these and so on but keeping the same variables.
I've tried assigning the plan configs numbers 1 - 3 and then using if statements to say if PlantConfig=2 use this set of equations. But I am a novice at MathCad and can't fine help locally.
Thank you,
Corey
12 REPLIES 12
Corey,
Have you solved this problem, if not would you upload a worksheet.
Mike
Raiko
(To:CoreyKerns)
Hello Corey,
it is not easy to guess what you're after (without an example that is), but maybe this will help. It works fine in the attached MC11 file
Raiko
Raiko Milanovic wrote:
Hello Corey,
Raiko
Raiko,
While your worksheet is a valid option, it could be nothing like what is required. Instead of second guessing, Corey should provide a worksheet for us to work with.
Mike
I'm sure it's something like what is required. I agree that seeing the original worksheet would help a lot though (as always!)
OK, its clearly close to what is required, but you get my point with the worksheet.
Mike
You have ideas but no data. You should have several data tables relating pertaining to each type of configuration. From there it might appear some sort of inductive idea how to apply some optimization scheme. The work sheet in example does not seem to relate to your unknown project.
Would something like this work for you? You could always implement some type of program to choose the i's based on some other parameter if you needed to.
Stephen,
No worksheet to work with - no point trying to help.
Mike
Stephen,
Mike
This web communities has the fine feature of training the memory [at least mine]. It is so difficult to keep track that instinctively it "punch card" in the gray matter. The project does not have data from collection only conclusive entries. So, what the collab has is only a "bingo card". There was a similar "bingo card" project in the former Akiva forum, but it was about tomatoes.
>I am a Virginia Tech Grad student and a Coast Guard officer doing some thesis work in Ship Design<
_________________________________
Mathcad works with numbers, data, functions, equations ...etc
But you have nothing for collabs !
There are a huge number of ways that can be made to work. One that should be nearly independent of version is attached.
The question is: what was Corey after ?
1. la greluche rose
2. un australopithéque
3. the Graal
Attached an almost "infinite passerelle", c/w the discretized range + export.
