New service release M010 of Mathcad Prime 2.0
VladimirN
24-Ruby II
Hello!
New service release M010 of Mathcad Prime 2.0 is available under "Order or Download Software Updates" on PTC's site, here: https://www.ptc.com/appserver/cs/software_update/swupdate.jsp
List of bugs fixed in Mathcad Prime 2.0 M010:
Microsoft Hotfix's:
http://support.microsoft.com/kb/2652531
http://support.microsoft.com/kb/2588096
PDF "Read This First" guide for M010 service release can be found in the attachment.
6 REPLIES 6
"Mathcad Prime 2.0 Help Center" now is available on the Internet (it works better with Internet Explorer): http://www.ptc.com/cs/help/mathcad_hc/prime2_hc/index.jspx
You can choose your language by clicking on the tab "Configuration" (yellow star) and then select "Language":
(To:VladimirN)
The keyboard shortcuts pdf still is faulty. E.g. "{" is unfortunately NOT a shortcut for local assignment as it used to be.
Werner Exinger wrote:
... "{" is unfortunately NOT a shortcut for local assignment as it used to be...
This only works if you press "Shift + {".
(To:VladimirN)
No, unfortunately not. Sure due to localized (German) keyboard layout. To get "{" I have to press "Alt-Gr + 7". Combination with Shift not possible.
By trial and error I found that pressing "?" (that is "Shift + ß") does the job.
Not a single of the seven shortscuts you copied from the PTC keyboard manual is working. For some you can find the keystroke by trial and error, for the two else commands I was not lucky.
PTC sure should fix this!
I use Russian/English keyboard layout (and Mathcad Prime 2.0 M010 with Russian language) and shortcut "Shift + {" works fine for me. Can you change keyboard layout to English and test it?
P.S. Anyway I sent this issue with keyboard shortcut to tech support.
(To:VladimirN)
Switching Prime2 to English from default German with parameter "/culture:en-US" does not change anything.
Switching the keyboard layout obviously would not be an option. But of course it "works", the keybd short for local assignment is now "Shift + ü" instead of "Shift + ?". BTW, the "ß/?" on German keyborads is right to the "0" in the top row, the "ü/Ü" right to the "P" in the second row from the top (not counting function keys).
And, no - I won't change the physical keyboard of my notebook! 😉
