Hi all,
I am trying to obtain the equation of a line (p'/p=1.0, the top line) from this image of the graph. The graph is in log scale and I have no reference to the original source of the graph, hence have no equation for it. Is there anyway to use Mathcad to obtain an equation. I am using Mathcad prime 9. Thanks in advance.
Thank you so much!
Here are my 2 Cents worth.
Of course it only covers the straight line for ratio=1
