OdeSolve for 2 point BVP
JohnRudnicki
I am trying to solve a two point boundary value problem. Instead of three initial conditions for the problem, I am giving the value at the end of the solution interval. Can I use odesolve? My initial attempt (below and in attached worksheet) was not successful. If not what else? I have not solved this type of problem before. I know "shooting methods" are one possible approach, but I do not know how to set this up in MC. Any help would be appreciated. FYI I am using MC14, but saved the sheet as MC 11.  Thanks.
You might consider the attached PDF article from Dr. Tom Co 11/3/2008. Mathcad 15 and Prime 8 worksheets attached.
9 REPLIES 9
Here's another approach using Laplace transforms. I think original content is courtesy of Luc Meekes.
Thanks. I will take a look.
bvp.pdf and BVP_15.xmcd were very helpful, but I could not open the *.mcdx files. What kind of mc files are they. (Not sure the Laplace transform approach will work since the problem is non-linear).
Sorry. Never mind. Just saw they were prime files and downloaded Prime to open. Thanks again.
LucMeekes
(To:JohnRudnicki)
I had to rewrite the differential equations, or Mathcad 11 would not understand. (It seems it likes the highest order differential on the LHS better).
Then a little experimenting gives:
Is that close enough for you?
JohnRudnicki
(To:LucMeekes)
Yes! Nice. Thanks. John
(To:LucMeekes)
If its not close enough then the value for w10 can be improved by turning the solve block into a function of w10 and use either another solve block or the root() function to get the 'optimal' value for w10 within Mathcad's numeric precision.
JohnRudnicki
(To:Werner_E)
Thanks. Good to know.
