Odesolve, possibilty to use values of the timestep before in a solve block?
fgörlich
Can I use prediction outcomes y(t) of an ode the timestep before in a solve block?
thanks,
Fabian
LucMeekes
(To:fgörlich)
Please attach your worksheet to clarify your problem.
You may have to zip it first. A serious bug in this forum often prevents from attaching a mathcad file. In Windows Explorer click with the right-mouse button on the mathcad file and select 'Send to' -> 'Compressed (zipped) folder'. The resulting .zip file can be attached.
Give please more information! Pictures etc
LucMeekes
(To:fgörlich)
Here is an example. (only minimal example)
I want to use the the value of y0 from a previous integration step in B(t,y). The solution y0(t-1) should only show what I mean. I want the y0 value of the integration step before. Is there a way to do this?
best regards,
Fabian
