Operaciones dentro de tabla
juniormera
3-Newcomer
Estimados todo
Buen día
Mi consulta es como puedo realizar operaciones dentro de una tabla para que cuando los datos de una columna dependan de otra pueda calcularlos automáticamente.
Gracias
(To:juniormera)
Please state which version of the program you are using. Real Mathcad (Version 15 and below) or Prime.
What exactly you are referring to with "table"? Primes table which is only a not very useful way to define vectors or a Mathcad matrix.
Obviously you are used to do calculations in Excel but you have to keep in mind that Mathcad is a much more powerful math program. So stop thinking of cells, columns and tables and start thinking in mathematical functions because this is it when one variable depends on another.
It would be helpful if you could provide a specific simplified example of what you are trying to do.
Would this help:
(To:juniormera)
Would this help:
Utilizo Mathcad Prime, la consulta iba en el sentido de que la columna N60 pueda generar resultados automáticamente ya que como se puede apreciar depende de la columna Nspt.
Tiene toda la razón, la costumbre de utilizar siempre Excel no hace confundir las cosas.
La consulta era para ver si es que es posible lo explicado anteriormente.
Muchas gracias
Mathcad is not EXCEL
(To:juniormera)
The variable N60 (a vector) should contain the correct values when you display it via N60=
Unfortunately Prime will not show those values in the table. The reason is that the table, which was introduced wtth Prime, is for input only. In my opinion it would be more valuable to implement such kind of table as an option for an alternate display of a matrix. But thats not the case.
