Overlaying Contour Plots
Jbryant61
Hi. Can someone give me a pointer to overlaying a sub contour plot on an already plotted contour. I want to illustrate graphically a region that is of particular interest to me.
Jason
StuartBruff
(To:Jbryant61)
Do you mean something like the attached, Jason?
Unless you have some particular reason to have a mostly empty array, you are probably better off using x and y co-ordinate matrices to specify the x and y points rather than using the Axes limits.
Stuart
StuartBruff
(To:Jbryant61)
Stuart
Jbryant61
(To:StuartBruff)
Thanks Stuart - I'd forgotten about the alternative notation to use for the graphic!
J
Jbryant61
(To:StuartBruff)
How would I add a single point onto the contour such that it was identified by a wavelength number i.e. the coordinate 540, 610 for example?
Jason
StuartBruff
(To:Jbryant61)
Jason
Try the attached, Jason.
Stuart
