POLYNOMIAL GENERATION
Anousheh
Would you please see the attached worksheet and help me to generate a polynomial for p(alpha)?
Thanks for your time and help.
Anousheh
(To:Anousheh)
What was the problem? The divison by zero because of the (....)^(1/alpha)?
p(alpha) is not defined for alpha=0.
5 REPLIES 5
AlanStevens
(To:Anousheh)
Use the same method but don't go too close to zero. Start xx at, say, 0.001.
Alan
Hello Alan,
Thank you so much for your reply. It works.
Anousheh
(To:Anousheh)
Hello Werner,
Thank you again for your time and help. I appreciate this very much.
All the best,
Anousheh
Hello Werner,
Could you please tell me how to write the actual POLYNOMIAL FUNCTION?
I tried to use "Symbolic Evaluation" sign, but it didn't work!
Anousheh
