POSSIBLE BUG IN MATHCAD 15 M050
regcurry
I have a repeating problem in the new release of Mathcad 15, namely the M050 release.
  1. I frequently use reference sheets.  If I make a change in the reference sheet from the main sheet, close the reference sheet by saving it, it does indeed change the reference sheet in its location.  However, the main code frequently does not recognize the change.  If I simply close the main code and reopen it runs correctly with the change I made before closing.
  2. I frequently experience a similar problem when just making any variable or formula change to a sheet and rerunning the sheet.  It doesn't recognize the change.  Again, if I close the sheet and reopen, it runs correctly.  Also, if I make the changes at another location in the sheet and paste it into the place where I wanted the change, the sheet runs correctly.
  3. Frequently, it does not recognize changes to a vector or matrix index [j until I close the sheet and reopen and then run.
I did not have these problems in the M045 release.
Has anyone else experienced this?
Until resolved, I am returning to the M045 version.
Reg Curry
Reg
That's the way Mathcad always worked for me, long before version 15.
Oh!  mea culpa. 😱🤪
Thanks much.
Reg
Reg
VladimirN
(To:regcurry)
Send your issue via "Mathcad Support Center": https://support.ptc.com/support/mathcad_supportCenterOpt.htm
Thanks; however, I do not have a support package.
Reg
