PTC Mathcad Prime 3.1 Converter
jsantiago-2
I'm trying to convert an old Mathcad file (.mcd) using the converter included with the subscription to Matchcad but the conversion fails and I get a file with the following text,
<?xml version="1.0"?>
<ConversionLog Date="28/11/2016 01:11:31 p.m.">
  <Errors>
    <FatalError Text="Mathcad 15 M010 or a later version is necessary to run the converter. Please install Mathcad 15 M010 and then restart the converter." />
  </Errors>
</ConversionLog>
Any help?
6 REPLIES 6
You MUST have Mathcad 15 installed on your computer for the conversion to execute.
<Errors>
Can you start Mathcad 15?
I have a student license for Mathcad, does that mean I have to buy a different license to be able to use the converter?
You can download a 30 day free trial of 15, that should get you where you need to go (at least for a month.)
Or, you can post the old file and ask a good samariton  to convert it for you.  (If you are allowed to post the file.
Thanks so much, I'll go ahead and download it.
LucMeekes
(To:jsantiago-2)
And then, before installing, you might want to make sure that you have the latest service release of Mathcad 15 (M045), or get it here:Download PTC Mathcad 15.0 Free | PTC
The answer is:  go find another math program.  I've been a MathCAD user since 1995, so I'm not happy that it's gotten this stupid.  Way to alienate your customers, PTC.  Prime is not an upgrade, it's a downgrade, who knew?
