Parameterized solve block issue
mlabree
Greetings. Refering to the attached, I have two solve blocks. The second (right side) is the same as the first (left side), except I've unsuccessfully attempted to parameterize the result such that I may vary the two constants (dy and L). MathCAD seems to have thrown up on this for some reason. Any help would be appreciated.
(To:mlabree)
The error message is nonsense and misleading. Simply remove the inline evaluation after find() and it works OK.
(To:mlabree)
That did the trick - many thanks.
