Hello Everyone.
To : How to eliminate 4 segments that are NOT a side of pentagonal prism ?
Thanks in advance for your time and help.
Regards.
Thanks for your hints, Ttokoro.
( Ttokoro, your hints should attach with an output. Because of might be followed with MathCad 15. )
Regards.
You can set same line color for top cap 24 lines. P(1,2,24) has Red lines.
This is by Werner_E.
With cap.
I greatly appreciate your time and help, Ttokoro. I got it.
Best Regards.
Loi.
Just add the position you want to set the plots. [x,y,z]^T
Interchange between X-axis and Z-axis ?
Best Regards.
