Can someone help me recover this corrupted file? I'm not sure what happened, I got done with it, saved it, and now it's throwing an error message and won't open.
Your file was somehow truncated so it can't be said how much of the original content is missing.
Find attached the repaired file but its very likely that its truncated and things are missing.
Thank you so much, it opened and worked well. I very much appreciate it!
