Hi, everyone,
For a vibration SDOF system, when I defined the units for variables like spring stiffness, mass, damper constant...
Mathcad tells the plot fails, but when I delete the units, it succeeds.
Please see the attachment for both cases.
Looking forward to your help.
Thank you
Shawn
Please see the attached.
Referring to A1:"m" was a variable, I believe you meant it to be a unit.
Created a range for "t" and it appears to work.
I hope this helps.
Norm
I hope this helps.
Norm
You are my hero, man!
