Plot of Fourier Series
ptc-1368288
On 4/24/2010 12:00:33 PM, hsbhela wrote:
>Hi,
>I want to plot very simple
>function using fourier series.
>Many thanks in advance!!
______________________________
There are many ways, not all equivalent depending upon the function to be converted.
Here is a very difficult one, done well.
You will surely get more specific help from *.XMCD users.
jmG
5 REPLIES 5
>>Hi,
>converted.
>from *.XMCD users.
>jmG
Sorry, Jean does not work in mathcad 14
See
http://twtmas.mpei.ac.ru/mas/Worksheets/Fourier.mcd
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
Thank you very much! Could you please tell me what you mean by *.mxcd users?
>>>Hi,
>>converted.
>>from *.XMCD users.
>>jmG
>See
>Fourier.mcd
>Val
_________________________________
Val,
The web collab is a bit coco these days. Most of the days the web collab is down for up to 6 hours at night local time. If I click on your link, it tells "Opps, link is broken". It could be Mathcad 14 does not read grouped definitions, a modified version is attached for the collab. If that modified sheet does not work, then a case to have "Doctor PTC" repair. In fact, repairing Mathcad 14 is equivalent to going back to Mathcad 11.
Thanks Val for your attention.
Jean
>by *.mxcd users?
Up to Mathcad version 11, the extension was *.mcd
above 11, the extension is *.XMCD.
Mathcad does read lower versions but not higher versions.
What that means is that if your sheet is in 14, only 14 will read.
There is a huge community at lower versions.
Now, you have removed your sheet and message, at least I don't see it .
jmG
jmG, that wasn't exactly my Budapest algorithm. The Fourier coeffs. may be accessed from the CFFT run automatically and no integrals are involved. Here a hasty re-post with the data you just now supplied with minor correctios. In MC11 from MC14 MO.
>corrections. In MC11 from MC14
>MO.
Yes Theodore, I have your CFFT and all that. The CFFT extract and reconstruct does work generally up until a project fails and where the Budapest method works. I remember, at some point you were desperate and nearly abandoned the method, I didn't. Your Budapest algorithm will be for ever in my MCADeng collection, nicely credited to you.
Thanks for your attention.
Jean
