I am trying to plot the curves of the properties of monoethylene glycol solutions in water, working from the parametric equations given in M. Conde Engineering "Properties of Working Fluids - Brines" (http://www.mrc-eng.com/Downloads/Brine%20Properties.pdf). Ultimately, I want to show the curves cut off properly at the freezing point line, as in the Conde document, and also to be able to show index lines for a specific temperature and glycol concentration. But I am struggling to get even the curves to plot correctly. If I set up the equations using range variables for glycol concentration and temperature I get the right sort of graph but with 'flyback' lines between each curve. Here's an example, for the dynamic viscosity; the various curves are for 0%, 10%..60% glycol in water.
I have found the various discussions here on plotting families of curves and waterfall curves. I am trying to follow the method illustrated by Valery Ochkov in his example sheet 2D_Plot_y_x_a.xmcdz, but I am not getting it to work for me. I am getting error messages like 'These array dimensions do not match' and 'All evaluations resulted in either an error or a complex result'.
I am using Mathcad 15 (M005), but I am not very experienced in using Mathcad for matrix manipulation; I am not sure I am even reading the example sheet correctly. Can anyone help?
Gerard
You are trying too hard ![]()
If you plot a vector on the x-axis and a matrix on the y-axis, where the matrix and vector have the same number of rows, then you get a line for each column of the matrix. You don't need any program to do this, but I did put in a helper function that makes it easier to fill a vector using a range.
Thanks for this solution too; quite different from Valery Ochkov's. His appears to draw the curves forewards and backwards as a continuous line but yours draws a series of separate curves - very neat!
try "draw" for curve type rather than "line"
I'd seen your similar comment to other threads before, but had not previously understood it. This time I found where the curve type can be changed. I must say the Mathcad User Guide is not very forthcoming about the curve types; I had not seen them - maybe I hadn't had the need - previously.
Thanks for the program and for correcting my graph.
There's one thing I am not sure I understand; that is why the format of ϱ(T) as I entered it is different from your graph. If I write ϱ(T) on the axis placeholder, it doesn't work, but if I copy it from the program, it does work. Presumably there is a format error, that as I write it, it appears as a function but as copied it has another format. What should that format be?
Valery is playing games with variable names. Type
r,
Ctrl g,
Ctrl Shft k,
(T)
Ctrl Shft k
That gives you a variable name, whereas
r,
Ctrl g,
(T)
gives you a function definition with T as the argument.
So that's what he did, and how he did it. Thank you.
Thanks to everybody who contributed. I've learned (sometimes re-learned) a lot!
Thanks Ricardo an sorry Gerard.
I have the description of this method
But have no time to translate it into English.
See please pictures from this chapter of the book.
Sorry? For what? You have been a great help. I should be thanking you more.
I started with your solution simply because I am reading your new book "Thermal Engineering Studies with Excel, Mathcad and Internet". After all the help I have received in this thread I now reckon I could make any of the suggested solutions work for what I wanted to do (I am now successfully hiding/not displaying the parts of each curve for temperatures below the freezing point of the mixture, and am working on the boiling point cut-off). I marked Richard's suggestion as the Correct Answer simply because it was easier for me to follow as I was re-learning how to graph data from matrices; now that I have grasped it, I see your solution works equally well.
I really should make more frequent use of Mathcad so I don't have to ask these beginners questions from time to time. But nowdays I seldom have the opportunity to get my hands dirty in the engineering maths; it's almost all the management side now, and providing guidance and information to the younger engineers when they get stuck.
Many thanks,
Gerard
Thank you for the link to the book chapter. Google Translate (https://translate.google.com/translate?hl=en&sl=ru&tl=en&u=http%3A%2F%2Ftwt.mpei.ac.ru%2FTTHB%2F5%2F3%2Findex.html) does a good enough translation for understanding.
Actually, with all the help I got from you and others I now have the worksheet working. I just have to tidy it up for good presentation; at the moment it contains a number of redundant sections and check results.
