Prime 10 Text box
DZ_7358918
Prime 10 Text box
Hi. As a beginner I looked at
https://community.ptc.com/t5/Mathcad/Mathcad-Prime-10-Text-Box-Advanced-Controls/m-p/952250#M212068 ...
and tried to modified it to a simple comparison if a value "a" is less or bigger than 1. For example an unit check of stress in some member is a=0.86. If a < 1 then member pass, if a => 1 then member fails. But a message "a" is undefined at row xxx appeared and I could not find a reason. I am sure that it is easy for experienced people in JScript. Thanks. D.
(To:DZ_7358918)
You would have to attach the sheet with the failing component.
If you get the message you described it means that you had used variable name "a" in your script. have you defined variable "a" in your script and assigned it to the input variable? Note that you can't expect the script to know the variable name of a Prime variable.
(To:DZ_7358918)
DZ_7358918
(To:Werner_E)
Hi. Thanks for a prompt answer. Finally I have found where I did a mistake.
It was surprise for me that when I gave away rows with definitions of TextBox colors,
the color of field stayed as  it was at that moment, so green, when it was green or red when it was red:
   TextBox.Font.Size = 23;
   if (Inputs[0].Value[0] > Inputs[0].Value[1]) {
         TextBox.BackColor(0x00BB00);
         TextBox.ForeColor(0xFFFF00);
         TextBox.Text("PASS");
   } else {
  TextBox.BackColor(0xFFCCCC);
              TextBox.ForeColor(0xCC0000);
TextBox.Text("FAIL");
When I rewrite rows into a new command of TextBox,  result was without color -  transparent field.
I could not find till now where I can define field properties.
Have a nice day.
D.
