Prime 4.0 crashes with eigenvecs function
bsimpkins
hi all,
i'm running a recent install of Prime 4.0 on Win 10. i'm doing a bit of matrix math. Using eignenval is fine but eigenvecs is problematic. It might solve once or twice but when i go back up to change a parameter value, the sheet tries to recalculate eigenvecs, stalls for ~10 seconds, then shuts itself off!
sheet is attached.
cheers,
blake
SOLVED
Enabling the "multi-threading" option under calculation is causing the crashes. Disabling multi-threading stabilizes the computation.
Incidentally, this is the 2nd problem with multithreading i've found. in Prime 2.0, enabling multithreading caused sheet calculations to be carried out out of order, so some would fail because earlier calc weren't completed.
10 REPLIES 10
(To:bsimpkins)
I changed the values of V1 and V2 a few times and ran into no error whatsoever. Prime 4.0, Win10 64bit
-MFra-
(To:bsimpkins)
Everything is fine with me too. Maybe he needs a good antivirus (excluding free ones)
UPDATE
rewrote the sheet in Prime 2.0 on Win 7 machine and it runs fine (and considerably faster).
(To:bsimpkins)
You should have stated which values you changed in which way before you ran into the error you described.
Do you still experience the same error when using your new Prime 2.0 sheet with your Prime4 installation?
SOLVED
(To:bsimpkins)
I see!
I can confirm that enabling multithreading produces the very same effect you described for me, too.
Bad bug, indeed!
DJF
(To:Werner_E)
This is interesting.  I had to turn off multi-threading in 3.0/3.1 or it always crashed.  4.0 I've had no issues until now - but I do confirm this bug.  (win 7, 64)
speaking of bugs - does 4.0 close for anyone else if you double click the round (M) button in upper left?
(To:DJF)
Never tried until now, but yes, it does. Its a regular close - it asks to save the currents worksheet, etc.
DJF
(To:Werner_E)
Ah, so it is.  Well, it's good news I won't lose my changes.  But still a rather surprising 'feature' to have MC shutdown if I'm a little over-eager on my clicking.
(To:DJF)
Prime sure has some surprising features (probably in lack of more useful ones). Just think about the absolutely non-standard and awkward way they implemented viewing and scrolling in larger matrices - that slider is a pure horror!
