Prime 8.0 How can I plot a circle
Snowshoeman
How can I plot a circle in the X-Y plane, only knowing the radius and location of the circle center?
I have Mathcad Prime 8.0.
Cornel
(To:Snowshoeman)
27 REPLIES 27
Cornel
(To:Snowshoeman)
Thank you!  That was easy.
One more request.  Is there a way to modify the above where there is a circle intercept at (0,0) ?
Thanks for your help.
(To:Snowshoeman)
I am not sure what you mean. If you know the center of the circle and if you demand that (0,0) should be a point of the circles circumference, you sure are able to calculate the circle radius and so can use the very same approach which was shown to you.
Here is a circle function I often use when I have to draw a circle.
You may use it to draw partial circles
to draw regular polygons
or to play around and create mandala like pics
Prime 9 worksheet attached
Sorry.... I was not clear.  I mean that one point on the circle will be at (0,0) with a center in Quadrant 1 at a point (x,y).
(To:Snowshoeman)
Yes, I had already suspected that and therefore suggested calculating the radius (as the distance between the two points, with Pythagoras, r= sqrt(x^2+y^2)) and then using the method already suggested or the function I posted to draw the circle.
Thank you!  I will try to plug in your equations.  I have Prime 8.0 so I could not use it directly.
This this bit of programming [NaN NaN} ?  Looks like the first trial bombed.  I am a novice at programming.  See attached.
[NaN NaN] makes pen off for the plot line.
Thanks!!
(To:Snowshoeman)
Hope this helps:
BTW, you sure can use 400 points to make the circle but you would be surprised that even much less points make up a quite good representation of a circle as well.
Thank you!  It works!
Bob
Werner,
Update:  If I resolve the point as a radius, then compare that radius to the radius of the circle, the problem is solved I believe.
In relationship the above math, is there a boolean or math routine to determine if a X-Y point is inside or outside the circle?  Can suggest a tack to take to solve this problem?
(To:Snowshoeman)
@Snowshoeman wrote:
Werner,
Which problem?
Not sure what the problem is!?  A point is inside the circle if its distance from the circle center is less than the circle radius.
You may use a test function like this:
Playing around ...
Worksheet in Prime 6 format attached
I like what you did...  I would have handled it a bit more rudimentary.   But your solution is best.
Thanks!
LucMeekes
(To:Werner_E)
For those limited to express, here is a set of functions to draw shapes:
And you can stack the result to create complex shapes, such as the CE mark:
Thanks!
This looks very handy!
(To:ttokoro)
Nice, but why only circles parallel to the xy-plane?
(To:Werner_E)
Playing around with the inscribed circles of the surfaces of a dodecahedron
Nice!  Thank you.  Will work for future programming..
Very cool!  Thank you
ttokoro
(To:Werner_E)
Thanks show us not x-y plane plot. I try it.
(To:ttokoro)
ttokoro
(To:Werner_E)
Thank You!
